| def | __init__ (self, trial=-1, background_color=color.RGBColor(0.6, 0.6, 0.6, 1), are_both_hand_controllers_visible=False, is_left_hand_controller_visible=False, is_right_hand_controller_visible=False, is_left_hand_visible=False, is_right_hand_visible=False, skybox="", global_lights_intensity=0, ambient_light_color=np.array([1, 1, 1]), objects_emit_light=True, side_view_on_pc=False, augmented_vision=False) |
| def | place (self, visual_object, the_3D_world) |
| def | placeUI (self, o) |
| def | to_json (self) |
| def | set_augmented_vision (self) |
| def | write (self, fp) |
| def | AddInteraction (self, events=[], callbacks=[]) |
| def | AddPointingCursor (self, pointingCursor) |
| def | place_contingent_cursor (self, pointingCursor) |
| def | place_pointing_laser (self, pointingCursor) |
| def | fill_in_results_file_column (self, column_name, value) |
Parameters
trial : The default is -1.
background_color :The default is color.RGBColor(0.6, 0.6, 0.6, 1).
skybox : "Night", "BrightMorning", "Cloudy", "Afternoon", "Sunset", "MilkyWay"
DESCRIPTION.
The default is "".
global_lights_intensity : number from zero to undefined upper limit (as in Unity).
Six sources of light are placed above the XZ plane (and approximately
above the origin)
to induce some strong shading of the objects in a scene. This is
helpful for instance to clearly see the sides of an object such as a
cube, especially for demos where shapes are not too far from the origin.
It is independent of whether 'skybox' has been set to one of its
possible arguments.
The default is 1.
ambient_light_color: a triplet of red, green and blue values.
This is the color of an ambient DIFFUSE light.
(cf "ambient light" in Unity documentation)
The default is np.array([1, 1, 1])
objects_emit_light: True of False.
it is a mode in which all objects emit light, ie objects can be
seen without any light source in the scene.
(cf EMISSION mode in Unity).
The default is True.
side_view_on_pc : True of False.
DESCRIPTION. When True, the PTVR window (on your PC) will show you
a "side view".
This is as if the PTVR window showed the view from a camera looking
laterally at your subject (at its headset actually).
You can rotate this view with your mouse.
This is convenient for didactic purposes.
The default is False.
Returns
None.
Definition at line 109 of file Scenes.py.
